April 29, 2011, 17:32 |
Swirl Chamber
Rep Power: 15 |
which is the best turbulence model for modelling high swirl combustion chambers? Is the k-epsilon model suitable enough? The fluid flow has swirl factors from 1 to 10. Greetz |
May 2, 2011, 05:31 |
Kailash
Rep Power: 15 |
hi,
I would suggest you to use RSM. But I have seen some literatures proving k epsilon model to provide results very close to that of RSM (only for certain problems not always guaranteed). Its better to run RSM if computational cost is not an issue. Cheers |
Howe to get swirl velocity component in 2D axisymtric swirl modeling | Perra | Fluent UDF and Scheme Programming | 2 | March 6, 2018 03:14 |
Swirl in Pressure Swirl Atomizer | varunrajendra | FLUENT | 0 | August 19, 2009 13:09 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 11:54 |
Swirl and Tumble Ratios in IC Chamber - Turbulence | Hussam | FLUENT | 0 | March 7, 2009 00:41 |
Swirl in backflow on pressure outlets | Jonas Larsson | FLUENT | 17 | February 3, 2000 03:14 |
