CFX For Heating Coils
Old   April 19, 2011, 23:03
Default CFX For Heating Coils
zephyrus17 is on a distinguished road
What would be the best turbulence modelling/setup to analysis airflow through convection coils? Physical testing shows a drop of around 40Pa with actual coils, but the CFX analysis only shows a 1Pa drop with K-e at 5% turbulence.
zephyrus17 is offline   Reply With Quote
Old   April 21, 2011, 08:32
seaharrier is on a distinguished road
Maybe you can consider the real wall roughness,
seaharrier is offline   Reply With Quote
Old   April 21, 2011, 08:40
I've thought about that, but it shouldn't affect it that much. All the 'walls' are smooth as they're made from sheet metal, or by extrusion.
There are fins 0.2mm thick, 2mm apart. There are only 2 rows of coils that the air has to pass through and they're arranged in a staggard manner.
My input is mass flow rate and outlet is an opening, though this should be fine.
Old   April 22, 2011, 00:19
The pressure loss should mainly come from the stirring of fins,
but how much does the turbulence influence the pressure loss?
maybe a little.
The inlet Re number can be estimated.
changing over to other boundary conditions of Inlet or Outlet perhaps does some effect, but the effect is unlikely so great level.
Old   April 22, 2011, 00:56
Speaking of fins, on the real thing, the fins are slightly wavy. Instead of "-------", they are "/\/\/\/\/\". Highly, highly exaggerated, of course but there's a slight kink. Could that have caused any major eddies of turbulence to impede airflow?
Old   May 15, 2011, 14:50
Vijaya Sekhar Gullapalli
gullapallivijay is on a distinguished road
Using RNG k-e and standard k-e an error of 40% is found in pressure drop compared to experimental results for liquid flow in plate heat exchangers. SST k-w models resulted aound 18% in a study. Up to 20% difference in pressure drop is observed using various near wall resolutions. What reference pressure is used while using air?
gullapallivijay is offline   Reply With Quote
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 03:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
PhD using CFX Rui CFX 9 May 28, 2007 06:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
