Ansys FSI and CFX (valve simulation)
Old   April 17, 2011, 17:20
Default Ansys FSI and CFX (valve simulation)
farianka is on a distinguished road
Hi
I have been assigned a job to simulate the air flow inside the valve of cylindrical shape. The piston moving inside the valve has a lid and by moving up and down it closes and opens the valve, hence regulates the flow of air through the valve. The piston is attached to valve via spring.
Now, I have no idea how to approach this problem, since I have no experience with this type of set up, I simulated the flow around the car in Ansys CFX previously, but this is different. I need to find out what load should be on the spring to achieve the optimum position of the piston inside the valve, hence optimum flow volume. I am aware that there is something called FSI in Ansys, that deals with valves, but not sure, if this particular case can be resolved via FSI and how complex it is. I have been offered this job, which I have to resolve within 12 weeks, but not sure if this is more complex than I thought. Can anyone advise on what is the best approach to model this?
Thanks a lot.
farianka is offline   Reply With Quote
ansys, cfx, fsi, valve
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 10:16
about valve closing problem during ANSYS FSI simulation ivy CFX 4 June 8, 2011 22:01
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 15:26
FSI using Ansys LS-Dyna and CFX YY CFX 2 April 9, 2008 07:40
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
