Problem with conexion under windows Expectation failed: PostGui_ogl.exe: |
April 1, 2011, 10:34 |
Sebastian
Hi everybody,
i work almost allways under linux but this time i have to correct my grid in Workbench and anytime when i try to start the Workbench from my computer under windows i get following error The following information may be useful to CFX support: src/QtWarningHandler.cxx(49) : Expectation failed: PostGui_ogl.exe: Fatal IO error: client killed The application has encountered an unexpected problem: PostGui_ogl.exe: Fatal IO error: client killed Please report this error, along with the circumstances in which it occurred. Alternatively, you may attempt to continue, but the application may be in an unstable state, and you should save your work and restart the application as soon as possible. I work under windows 7 64 bit, ATI Mobility Radeon HD 4670. I conect my computer through a ssh conexion with the server from my university. I dont really know why, but when i try from a diferent computer i dont have this problem, so i can start cfx and ansys without problem. I thanks you all in anticipation for the help. regards |
April 15, 2016, 12:40 |
ali
Rep Power: 18 |
did you find what was the problem?
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
help: udf compiling problem on 64 bit windows XP | Hsieh | FLUENT | 2 | September 10, 2009 05:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
UDF compiling problem in Windows | Mazyar | FLUENT | 1 | April 26, 2006 02:48 |
PVM RSH parallel setup problem Windows XP | abe | CFX | 11 | January 30, 2006 06:10 |
