Incorrect Drag Coefficients / Mesh Confirmation |
March 31, 2011, 07:22 |
William Nicholson
Rep Power: 15 |
I'm a third year MechEng student and currently meshing an aerofoil in ICEM, and modelling in CFX at various angles of attack. My lift coefficients are coming out with errors between 3% and 10%, which I’m ok with. My drag coefficients however are producing errors between 55% and 80%, which is obviously not good. So far I've tried re-fining my mesh, playing with the surface roughness of the aerofoil and tried different turbulence models. I've already had the problem with the force vectors being in the wrong direction, and rectified this so my drag force is definitely parallel with the flow direction. I have attached a few of screenshots of my mesh and would like to know how I might improve it, however I don't think it's too bad as my lift coefficients are coming out with the correct values. Any help would be greatly appreciated. Many thanks, Will Aerofoilmesh.jpg Halfmesh.jpg Wholemesh.jpg |
March 31, 2011, 07:29 |
William Nicholson
Rep Power: 15 |
Apologies for the double post, the forum said the first post didnt work.
Can I delete one of them? |
May 7, 2011, 20:38 |
Rep Power: 15 |
Did you do any modification for your "Reference Values"?
May 18, 2011, 12:00 |
Lloyd Moffatt
Rep Power: 15 |
Hi Mate,
Am doing a similar project and getting good results. I am using and inflation with more layers (20) and a smaller explanation rate (1.05). You must keep in mind what is physically occurring here. As the alpha of the foil increases the point at which the flow detaches creeps further towards the leading edge until stall. The drag on the foil is a results of the turbulent region in the detached wake region; where you have a coarse mesh: try adding a body or sphere of influence in the wake region. LM |
Incorrect boundary mesh connectivity | Mohsin | FLUENT | 0 | September 2, 2010 01:29 |
Final Year Project - CFD on Drag coefficients | jamesho123 | Main CFD Forum | 1 | September 15, 2009 21:50 |
How to mesh for drag estimation . | jeevan kumar | CFX | 0 | March 3, 2008 05:35 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
pressure. lift and drag coefficients | waqar mahboob | Main CFD Forum | 0 | July 25, 1998 03:34 |
