problem opening a cfx definition file with fluent
Old   February 18, 2011, 16:28
Default problem opening a cfx definition file with fluent
tasos
samaras387tasos is on a distinguished road
Send a message via Skype™ to samaras387tasos
HELLO TO ALL OF YOU,
I HAVE A PROBLEM IN LOADING A CFX DEF FILE TO FLUENT.
I PRESS "IMPORT->CFX->DEFINITION FILE" AND IT STARTS LOADING THE FILE BUT THEN DISPLAYS THE FOLLOWING ERROR
Reading "\"| utility fe2ram -tCFXD -d3 -m1e-08 \"\"C:\Documents and Settings asos\6ORUN\6orun.def\"\"\""...
Error: bad syntax. Usage:
utility fe2ram dimension read_format zoning write_format [inputfile [outputfile]]
dimension: [-d2 | -d3 | -surface]
read_format: [-tANSYS | -tCFX | -tCFXD | -tCFXR | -tCGNS |
-tFIDAP7 | -tFLUENT4 | -tFLUENT4UNI | -tGAMBIT | -tHYPER |
NOTE: I FIRST LOADED A MESH FILE
DOES ANYONE KNOW WHAT THIS ERROR MEANS?
WHAT CAN I DO TO FIX THAT?
samaras387tasos is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
