Flow Between Concentric Cylinders
Old   February 17, 2011, 05:43
Default Flow Between Concentric Cylinders
Maks
larscliff is on a distinguished road
Hello!
Please, could you help me?
I have the follow task:
Consider the steady flow maintained between two infinite concentric cylinders. Inner cylinder makes harmonic motions. Outer cylinder remains fixed.
Determine the velocity distribution between the two cylinders.
It's two-dimensional problem.
I've seen the similar task in VM46. But It isn't the same. Unfortunately, I don't know how to set harmonic motions...
If you help me, it'll be wonderful
larscliff is offline   Reply With Quote
Problem with transient solution of flow past a row of cylinders jostanek Main CFD Forum 0 January 6, 2010 13:16
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
PROBLEMS WITH ROTATING FLOW BETWEEN TWO CYLINDERS vitmalin CFX 2 October 11, 2006 08:22
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
