Refine mesh in Ansys
Old   January 13, 2011, 12:36
Default Refine mesh in Ansys
p@ri$2009 is on a distinguished road
Hello everyone,
I have a problem in Ansys 12. I have a 3D solid model which has a compllicated geometry and I want to refine the mesh of some volumes of it.Does anyone know how I can fix this problem?
p@ri$2009 is offline   Reply With Quote
Old   May 7, 2011, 22:26
zhenglun.wei is on a distinguished road
are you using Fluent? if yes, then you may use the adapted mesh concept, which you can find it in Fluent manual.
zhenglun.wei is offline   Reply With Quote
Old   May 22, 2011, 14:33
Smile
Originally Posted by p@ri$2009 View Post
Hello everyone,
Thank you very much for your answer zhenglun.wei.
I am using Ansys 12.0, multiphysics.
I think I found the answer, I think that i have to refine the area first and then to give the order to make the required volumes.I tried it and it works.
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 04:17
