Which Multiphase Model i can use?
Old   November 30, 2010, 12:46
Question Which Multiphase Model i can use?
Sai Chu
saiburry is on a distinguished road
hi, everybody,i got a problem but i dont know how can i solve it.
Now i have to simulate a model which is similarity like that: a air-water fluid flow into a parallel connection channel (actually, it is a plate heat exchanger) .
now i have to know the air mass flow rate or water mass flow rate in each channel, Which Multiphase Model is better? mixture model?
saiburry is offline   Reply With Quote
Old   December 3, 2010, 21:19
Kevin Erhart
kerhart is on a distinguished road
The choice of multi-phase model depends on several flow factors, including the presence and size of bubbles, and the importance of free-surfaces. Try the following link to help you decide what model is best suited for your application. It provides a pretty detailed discussion on the various types available in Fluent (not sure if you are using Fluent, but the same flow regimes should generally apply to any CFD program, the model names might vary slightly but the approaches are pretty universal).
http://progdata.umflint.edu/MAZUMDER...Multiphase.pdf
Kevin
kerhart is offline   Reply With Quote
multiphase model
Multiphase model and species transport Reginaldo Cotto FLUENT 1 June 6, 2024 05:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 17:01
multiphase model & separation naser FLUENT 5 June 9, 2006 07:12
