Meshing problem
Old   November 24, 2010, 23:11
Default Meshing problem
Derwin Parkin
derz is on a distinguished road
http://www.flickr.com/photos/derz/5205319511/
See this picture? Notice in the middle of these regions, the mesh is coarser in the middle. How can I eliminate this? I would like the mesh to be as fine as it is at the region-boundaries, all the way through the region...
Any thoughts? I've tried playing around with many options but can't seem to eliminate it with automatic/tets meshing...
derz is offline   Reply With Quote
Old   November 25, 2010, 06:51
Max Efficiency is on a distinguished road
On the left side in the settings look at sizing: When you decrease the Max Tet Size you force Meshing to use smaller (and more) elements to mesh your geometry.
Also try changing the growth rate. To achieve a slower growth in element size choose values close to 1 (e.g. 1.05).
Max Efficiency is offline   Reply With Quote
Old   November 25, 2010, 09:47
Amir Khodabandeh
akhokhay is on a distinguished road
this
I also think u set growing rate wrong.
u should inverse it or if boundaries are important use double method(it got different names, iirc in gambit it is bell method!) which get 2 values for each end!
akhokhay is offline   Reply With Quote
Old   November 30, 2010, 14:20
akhenathon is on a distinguished road
its a sizing ans infilation problem
akhenathon is offline   Reply With Quote
Old   December 2, 2010, 22:50
Darren Leong
Darren Leong is on a distinguished road
Hi Derz,
1. You'll have more control by editing through CFX-mesh. Reduce the body spacing from there when meshing. There doesn't seem to be an inflation layer around your model, may have problem with the turbulence models later on.
2. You can extend the inner domain to capture the wake area and have the coarser mesh as your outer domain. This eliminates errors at the domain interfaces (lost of flow information). The outer domain should be bigger to reduce the chance of blockage effect.
Darren Leong is offline   Reply With Quote
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 08:21
Gambit meshing problem nana ANSYS Meshing & Geometry 5 August 31, 2009 06:58
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 09:29
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
