ANSYS 12 DM, Mesh and simulation
Old   October 30, 2010, 06:42
Default Boundary interaction problem
Silverstone
shorion is on a distinguished road
Hi everyone.
I was just modeling some 2d problems and hit a snag. I have a flow and a block in the flow with a heat flux being supplied from the base of the block however, at the boundary where the block and flow meet there is no interaction.
http://i886.photobucket.com/albums/a...on999/flow.jpg
http://i886.photobucket.com/albums/a...on999/Temp.jpg
The temperature of the flow and block is right and the velocity field shows correctly but the heat isn't being transmitted from the block into the flow. Any ideas? Did I miss a setting somewhere along the line? or the model?
shorion is offline   Reply With Quote
Old   November 1, 2010, 09:50
Michael P. Owen
michael_owen is on a distinguished road
It's most likely just a scaleing issue. Scope your temperature contour to only the fluid and set the range to Local instead of Global.
michael_owen is offline   Reply With Quote
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 10:16
exporting the modified mesh from ansys dogo1234 ANSYS Meshing & Geometry 1 September 5, 2013 12:08
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
Mesh used for Combustion Simulation Stein CFX 5 May 14, 2009 19:24
