ansys 12.1 license error
Old   October 28, 2010, 12:58
Default ansys 12.1 license error
clarkent is on a distinguished road
I installed ansys 12.1 and its license manager to vista laptop. afterwards, i adapted the license file with my host name and flex id. when i try to run license wizard, i get "access denied", 3 times after i hit continue button. and the status are still :
ANSYS, Inc. License Manager status:
Licensing Interconnect: not running
Licensing Interconnect Monitor: not running
FLEXlm: not running
does anyone have an idea what might be the problem?
clarkent is offline   Reply With Quote
Old   October 28, 2010, 13:40
Daniel Baeriswyl
daniebae is on a distinguished road
Heya
start the ANSYS License Client Admin Utility.
Go to " Set License Preferences for User ***** "
and then set Global Settings to "Use Academic Licenses"
guess you are a student...does it works ?
daniebae is offline   Reply With Quote
Old   October 28, 2010, 14:14
Hi Daniel,
I just tried that, first it asked if i wish to set 12.0.1 0r 12.1, i chose 12.1.
but then i got "failed to retrieve license preferences. please be sure that you are able to connect the license server"
i am a master student and working as well. i ll use it for training purposes at home.
Old   October 28, 2010, 14:19
Daniel Baeriswyl
then may you have to be connected with your unversity for example with VPN all the time to have the right proxy server and the use academic license.
otherwise i dont know
Old   October 28, 2010, 14:34
i dont have internet connection all the time at home, but thanks though.
Old   November 1, 2010, 09:48
Michael P. Owen
michael_owen is on a distinguished road
You can't do this. The INCREMENT lines in the license file are created for a particular machine.
You will either need network access to the actual license server to check out licenses, or you will need to look into license borrowing.
michael_owen is offline   Reply With Quote
ansys, license error
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 06:17
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
