How to analyze a wind impact on a surface
Old   October 9, 2010, 09:50
Default How to analyze a wind impact on a surface
george85 is on a distinguished road
Hi. My name is George, I am an architect, and relatively new to Ansys, to be specific, I do not know anything about it. I got it yesterday.
I want to analyze a wind impact on my two curved surface.
First of all wich ANSYS sofware do I need? ANSYS ICEM CFD or ANSYS CFX?
Is there any kind of tutorial for this?
Thank you for all the help in advance.
george85 is offline   Reply With Quote
Old   October 18, 2010, 07:15
m.maneshi's Avatar
Mehdi
m.maneshi is on a distinguished road
If you would want to model wind effect on a solid body ( if the deformations are not negligeble) you need to solve a FSI coupling of Ansys multi field and CFX. Else you can model in CFX and import the results on the Structural analysis seperately.
m.maneshi is offline   Reply With Quote
Old   October 19, 2010, 11:11
Thank you for the reply Mehdi.
What I did is imported the .dxf file into Ansys CFD 11 and then created a surface out of it. Then created the mesh. Now I need to import it into the CFX right? How can I do that? There is no CFX file to be chosen at the File->Export menu?
Old   October 19, 2010, 16:17
m.maneshi's Avatar
Mehdi
Yes exactly, you can save the mesh as a CMDB format file and later import it in CFX or if you are using ANSYS 12 easily darg and drop mesh in cfx.
Cheers
Old   October 21, 2010, 11:10
thank you for the reply one more time. I am using an Ansys version 11.
can you be a little bit more specific about this:
I guess this is the next step after importing a meshed surface(I created in CFD) in CFX ?
Old   October 21, 2010, 17:21
m.maneshi's Avatar
Mehdi
I dont understand you, you created the meshed surface in CFD ???
after importing the mesh in CFX you need to set B.Cs and do the solution, later you can import pressures on the solid model for stress and strain analysis if that is what you are after.
Cheers
Old   October 23, 2010, 07:59
I run the ANSYS ICEM CFD v11, I imported a .dwf file, and then created a surface out of it. Then created the mesh.
The reason why I used ICEM CFD for all this steps is because, I know how to do it in this application. I do not know If this can be done in CFX also, but in any case, if it can be done, than I do not know how to do it.
So now that I did this the mesh, can I import it into the CFX?
Yes this is what I am looking for. Are there any kind of tutorials or at least help files for this? I tried using those from the Ansys application itself, but there are no similar ones to my solution (analysis of wind on a plane, bomber, cooler for processor... Also the results are not calculated as a pressure, but by "density" ? Why is that?).
Old   October 25, 2010, 13:34
Graham Knapp
gknapp is on a distinguished road
Hi George,
Just to let you know - you're taking on one of the hardest current topics in CFD here. I wish you luck with it but advise you to be cautious as it is very easy to build a simulation which appears to show one thing when the exact opposite is true...
The current best advice is to be very cautious with the use of CFD in structural engineering, and always to have some back up from wind tunnel or codes of practice.
best regards,
Graham
gknapp is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
swimming pool water surface motion due to wind J.Kim FLUENT 4 May 5, 2006 11:08
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
