Gambit/Fluent: Stress free boundary conditions |
Rep Power: 0 ![]() |
I have created a simple 2-d mesh of a moutain bike helmet which is basically a half circle at the bottom of a large rectangle (a circle subtracted from a rectangle). I have been told I need to specify stress free boundary conditions for the bottom edge (infront and behind the helmet) I can not find stress free conditions in the 'type' drop down box on the 'specifiy boundary types' menu, can anyone help? Also as I am using the fluent5/6 solver on gambit there is no inflow on the same drop down menu should I select velocity_inlet or mass_flow_inlet? I pressumed velocity inlet as I will be simulating air flow over the helmet. Many thanks! |
Please help?!
I basically just need to know how to impose stress-free boundary conditons to a mesh boundary using Gambit 2.2.30 or Fluent 6.2.16 software. :-) |
Logan Page
Rep Power: 15 ![]() |
from what i understand of your problem you can try using a symmetry BC on the bottom edge (front and back)
gambit fluent bc |
Free surface flow settubg boundary conditions and plotting velocity profiles | prashanthreddyh | FLUENT | 2 | October 21, 2015 09:58 |
Fluent accuracy and boundary conditions | Paolo Lampitella | FLUENT | 0 | June 12, 2008 06:25 |
boundary conditions simultating a "free" spray | mathias | FLUENT | 0 | March 28, 2006 08:15 |
Free Surface Flows / Ocean Waves / Far-field boundary conditions | Sundar Prasad | Main CFD Forum | 5 | May 4, 1999 10:25 |
free surface boundary conditions | Gerard Moroney | Main CFD Forum | 2 | November 17, 1998 15:49 |
