September 5, 2010, 14:20 |
Urgent help plzzzzz.
Hudda
Rep Power: 16 |
After I install ANSYS at my company, the user keep getting warning message says that
“can’t find user’s home. Could not save the configuration file! To avoid this message, define or check the environment variable HOMEDIR to local directory. POLYFLOW - what can i do to resolve your quick respond is appreciated. Hudda |
September 5, 2010, 15:23 |
you should check the environment variable HOMEDIR (windows environment variable)
September 5, 2010, 15:30 |
Hudda
Rep Power: 16 |
Thank you for your reply, but How???
September 5, 2010, 15:31 |
Hudda
Rep Power: 16 |
September 5, 2010, 15:41 |
my computer --> properties --> advanced --> environment variables
September 5, 2010, 16:02 |
Hudda
Rep Power: 16 |
September 6, 2010, 13:08 |
Hudda
Rep Power: 16 |
No it did not work, I thought it is a permission problem I gave the folder full permission for user still not able to save the message says. I do not know what to do...................any other thought plz let me know.
thanks Hudda |
September 6, 2010, 14:29 |
may be it will be useful:
ANSYS 12.1 Help "3.4.*Post-Installation Procedures Set the home directory. To set a home directory in Windows, you need to set a HOMEDRIVE environment variable to the desired drive letter (including the colon) and a HOMEPATH environment variable to the desired path. For example: HOMEDRIVE=C: HOMEPATH=\Users\Mine" you can find another Post-Installation Procedures. see help. Good luck. |
September 6, 2010, 20:59 |
#9 | |
Hudda
Rep Power: 16 |
Hudda |
September 10, 2010, 10:23 |
#10 | |
Hudda
Rep Power: 16 |
Hudda |
Urgent, Urgent, a UDF problem, PLEASE HELP!!! | Max | FLUENT | 1 | September 24, 2010 21:30 |
Urgent...urgent...plss!!! | astronome | FLUENT | 0 | October 16, 2009 08:17 |
tmerge urgent urgent | jessica | FLUENT | 4 | July 15, 2006 14:37 |
Urgent: need source Code K-Eps | Ace | Main CFD Forum | 2 | December 17, 2004 00:41 |
urgent questions? | bob | FLUENT | 3 | April 28, 2004 19:32 |
