#21 |
karan
Rep Power: 0 ![]() |
The issue occurred in the cross-section process. Since you don't pick the correct face as a limit. On the off chance that your model contains 3 bodies, and you need to pick and name a face in one of the bodies, you would be wise to conceal the other two bodies so you don't pick an inappropriate face. The stream limit id is an inappropriate face you picked. Return to your cross-section programming and rechoose the face, at that point there would be no issue.
#22 |
noorlina
Rep Power: 6 ![]() |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Add icoLagrangianFoam to FoamX | dyxu | OpenFOAM Running, Solving & CFD | 10 | June 11, 2008 09:53 |
FLUENT Warning | Jordi | FLUENT | 0 | April 21, 2006 04:41 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
