ANSYS Workbench mesh crashes (ANSYSWBU.exe problem) |
November 21, 2011, 19:42 |
#21 |
Pedro
Reggenzi, thanks for your help, but it didn't work here. The problem is still happening. I use Windows 7 Professional, 64 bits and Ansys 12.1. Thanks for your attention.
December 8, 2011, 22:16 |
#22 |
yasharif
Rep Power: 16 |
u r genius. it works with me now..!!wow
December 17, 2011, 08:59 |
#23 |
adri
Rep Power: 15 |
Hello!! I have the same problem. I start the Ansys 12.1, but when I start the DesignModeler or Mesh appears:
AnsysWBU.exe encountered a problem. A diagnostic file has been written: ..../AppData/Local/Temp/AnsysWBDumpFile.dmp I did everything that you said in the post: update drivers, install the environment variable ANS_OLD_ATTACH...and I work without Ethernet and I don't know what do! please help me! |
December 18, 2011, 09:48 |
#24 | |
Emre G
Rep Power: 15 |
did u try to give all permission to your ANSYS folder in folder C: ?? |
December 18, 2011, 10:11 |
#25 |
adri
Rep Power: 15 |
December 18, 2011, 10:52 |
#26 |
Emre G
Rep Power: 15 |
December 21, 2011, 10:46 |
#27 | |
adri
Rep Power: 15 |
I don't know what do |
December 21, 2011, 23:14 |
#28 |
Darren Leong
Rep Power: 16 |
If using an ATI card:
disable 'Catalyst A.I.' and 'Geometry Instancing' and set the bar to all the way to the left for the rest of the 3D settings or simply disable the card in device manager (which will help to identify if it's a graphics card problem in the first place) |
January 13, 2012, 02:00 |
Thanks
#29 |
deewakar
Rep Power: 15 |
Hey SAL
it worked for me too,... thanks for support |
March 23, 2012, 04:07 |
Re: Dumb file
#30 |
Rep Power: 15 |
Find the dumb file that is written by ANSYS. I disconnected from Internet and when I connected again it would give me the error "AnsysWBU.exe encountered a problem. A diagnostic file has been written:
..../AppData/Local/Temp/AnsysWBDumpFile.dmp" I have tried all the suggestions you guys are giving but nothing works. Rgds |
March 26, 2012, 10:55 |
#31 |
Rep Power: 15 |
Mine also worked! Thanks
May 21, 2012, 01:27 |
#32 | |
jianglei
Rep Power: 14 |
i had a problem ansyswbu.exe encountered a problem. a diagonstic file has been written: c:\docume~1\admini~1\locals~1\temp\ansyswbdumfile. dmp I had do it according to above ,but it does not go well. my ansys is 14.0 version. Last edited by dragonship2011; June 4, 2012 at 22:01. Reason: no answers! who can help me ? |
June 4, 2012, 14:53 |
#33 |
Emre G
Rep Power: 15 |
hi.
the problem still continues.. is there anyone can help on this issue? |
July 3, 2012, 14:36 |
#34 | |
sina
Rep Power: 14 |
thanks alot Sal |
July 13, 2012, 10:40 |
#35 |
Ali nabavi
Rep Power: 14 |
thank you so much sal
July 18, 2012, 02:53 |
#36 |
Darren Leong
Rep Power: 16 |
Hi Emreg,
What system are you using, i.e. OS and graphics card. Have you tried switching off the graphics card to see if the problem still occurs? |
October 17, 2012, 22:39 |
Thanks so much
#37 |
ASHRAF ALFANDI
Rep Power: 14 |
Thank you so much it was complicated problem for more than one week. thanks
October 19, 2012, 19:54 |
#38 |
Maksim
Rep Power: 16 |
October 22, 2012, 18:04 |
Ansys Workbench Error: "ANSYSWBU.exe encountered a problem" (Design modeler and Mesh)
#39 | |
Maksim
Rep Power: 16 |
Hello everyone!
Recently I recive a very strange / unusual problem / error, which, luckily, was solved (at the same time thanks to Google and people who also helped in the decision, giving recommendations). I want to help people and decided to describe the problem more completly. It happened with Ansys 13 after install the update for Windows 7 x64 (see attached): appear a fast window that say “ansyswbu.exe encountered problem” Error: ANSYSWBU.exe encountered a problem. A diagnostic file has been written: C:\...\Temp\AnsysWBDumpFile.dmp. Of course, for those who have turned on System Restore in Control Panel \ All Control Panel Items \ System \ System Protection, you can simply select the restore point, recorded before "these" updates, and everything will work fine. But for those who have been turned off System Restore, the banal removing updates will not help, because Ansys files have been changed. Also, you can simply restore the system, but why? If there is more simple and quick solution. Based on this forum, the below link and my own experience: http://www.topix.com/forum/com/anss/...A6HBDAD9S2I/p2 1) Many people are advised to do the following: Install the System environment variable ANS_OLD_ATTACH = 1 Advanced system settings / Environment variables On System variables select -> New On variable name -> ANS_OLD_ATTACH On variable value -> 1 2) But sometimes that does not work (or does not help everyone): This error is related to the fact that the operating system when you install the updates (for windows) changed the files belonging to the program Ansys, and located in the "My Documents" at: C:\Users\UserName\AppData\Roaming\Ansys; To remove the error simply rename the folder "Ansys", eg, "_Ansys". As a result of this operation, the software Ansys, will recreate the directory at (C: \ Users \ UserName \ AppData \ Roaming \ Ansys) with default parameters and the error will disappear. Also, Ansys, each time creating at "C: \ ... \ Temp \" multiple files / directories, they can also be safely removed, although their removal does not resolve problem, also typically, this folder is cleared after a system restart because it stores the temporary parameters (just the one person by the link above also recommends do it). Quote of the man which also decided to the problem (from link above): Quote:
Maksim Last edited by Maks001; October 22, 2012 at 18:53. |
November 30, 2012, 09:39 |
#40 |
sunliang
Hi Mask,
I'm a new learner and face the same problem. I tried these ways as you said, but they din't work. Could you give me some other advices? Thanks a lot. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
importing mesh from Gambit and other software to ansys workbench | mortazavi | CFX | 12 | May 30, 2012 08:38 |
importing mesh to ansys workbench??? | mortazavi | ANSYS | 0 | June 1, 2009 06:10 |
Problem importing ANSYS mesh, please help | Ankan Kumar | FLUENT | 1 | February 2, 2003 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
