May 4, 2010, 07:56 |
Help needed in ansys meshing
kjayatunga
Rep Power: 16 |
I am carrying out a flow simulation on a 3D wing which has varying aerofoils. So my model is that i have a box where cut out the wing geometry. Now I want to mesh a surface mesh in the wing using rectangular elements. I still could not do that using the workbench meshing software. Can anyone give me a suggestion
May 4, 2010, 08:10 |
Michiel
Rep Power: 17 |
Use ICEM CFD to create a structured hex mesh with the blocking abilities. Ansys meshing module has limited capabilities for creating an hex mesh, and wont be capable for properly meshing a 3D wing body with hex elements.
May 4, 2010, 12:20 |
kjayatunga
Rep Power: 16 |
Thanks a lot Michel. I also want to ask this as well most of the complex wing faces are meshed using triangular elements some of the publications that i have came across have used a tetrahedral unstructured scheme. Is hex is better than this. I want to clarify since my model is also has a complex wing which has a dihedral and a sweep so what scheme you recommend in order to simulate wake vortices.
Thanks again for the reply. |
Line Control in Ansys Meshing | Oli | ANSYS Meshing & Geometry | 4 | November 17, 2010 16:35 |
Ansys meshing | TypeSpeed | ANSYS | 5 | January 1, 2010 07:31 |
Hexa Block meshes in ANSYS Meshing? | siw | ANSYS Meshing & Geometry | 3 | July 31, 2009 11:40 |
[GAMBIT] Help needed with meshing! | fluentnoob | ANSYS Meshing & Geometry | 24 | June 6, 2009 18:41 |
urgent help needed for meshing in GAMBIT | chris | FLUENT | 0 | September 5, 2002 10:18 |
