Ansys Workbench + OpenSuse = Problem
Old   March 22, 2010, 06:39
Question Ansys Workbench + OpenSuse = Problem
Stefan
preibie is on a distinguished road
I want tied the new Ansys product "AnsysMesh" and "DesignModler". Both don't run on OpenSuse 11.1. The Workbench works fine but when I tryed to start the Design Modler ore AnsysMesh I only see the sandglass for two seconds.
Has anybody an Idea what I can do to run them an se more then the sandglass?
preibie is offline   Reply With Quote
Old   March 30, 2010, 06:41
Olli
Moelfus is on a distinguished road
I'm having the same problem. When I double click on the DesignModeler it's starting 1 of 10 times. I followed the instruction about 'focus stealing prevention', but the behaviour didn't change. But when the DesignModeler is running, it is running stable. I've called the ANSYS Support, but they couldn't suggest a solution. The only answer I could get was to install the mechanical update for linux, or wait till version 13 is available.
I'm using OpenSuse 11.1 as well. If I get it running I'll let you know.
Moelfus is offline   Reply With Quote
Old   March 31, 2010, 05:02
Stefan
we tried a lot of things an now it runs. What we have done is:
  1. install open suse 11.2 (before we had 11.0)
  2. install the newest driver for the graphic card (Nvidia quadro fx)
  3. installing the workbench and fluent
all is fine!
Preibie
Old   August 19, 2010, 13:33
Olli
Hi Preibie,
sorry for answering so lately. As you suggested I installed OpenSuse 11.2 which solved my problem. This is probably the only solution.
Regards Moelfus
Old   August 19, 2010, 15:25
Stefan
Hi Moelfus
some weeks ago opensuse 11.3 was launched. I tried to install fluent and also the workbench on a opensuse 11.3 system. I was very sorry but it failed!
Do you have some experiences about the problems with open suse. Because of that stupid things we want to use suse enterprise.
Preibie
Old   September 3, 2010, 05:45
Olli
sorry, didn't see your post. Fortunately we haven't upgraded. Do you think it is getting better if you are changing to Suse Enterprise? Isn't it the same framework? Well I'm no Linux expert, but I would try it before in a virtual machine.
Good Luck!
Olli
Old   September 3, 2010, 09:37
Stefan
I know that suse enterprise is the only linux distribution ansys will support. So I think it will work fine.
Preibie
Old   September 6, 2010, 12:53
Olli
Hi my Sysadmin just told me that you could try to change the default kernel that is install with 11.3 with the desktop kernel of OpenSUSE. Should be available through yast2. This helped on an other machine with 11.1.
Olli
airfoil drawing in ansys workbench Hammam ANSYS Meshing & Geometry 2 June 18, 2011 20:34
Problem with Ansys workbench 12 nolebb ANSYS 0 September 12, 2009 16:02
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 07:01
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 22:30
problem in reading ansys file satya bulusu Siemens 3 November 27, 2002 04:29
