CFX FSI From the Command Line
Old   March 20, 2010, 18:01
Default CFX FSI From the Command Line
Ryan Jamison
rjamison is on a distinguished road
Hello All,
I'm trying to run ANSYS CFX on Linux using the command line. I'm able to run CFX SS simulations without any difficulties. The problem comes when I try to run ANSYS Multi-field (FSI) simulations. This is an example of my command line:
/usr/local/.../CFX/bin/cfx5solve -def CM.def -initial CM_SS_001.res -ansys-input Solid.inp
As you can see I have to explicitly define cfx5solve path. The problem is when I run this in the command line I get an error saying that there is no ANSYS license, but when I run this through the CFX Solver I don't get this error! Do I need to explicitly define the path of the ANSYS solver somehow? Or is there something else? Thanks in advance!
rjamison is offline   Reply With Quote
FSI : CFX or Fluent? icemaniac178 ANSYS 1 February 19, 2010 07:33
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 15:26
FSI using Ansys LS-Dyna and CFX YY CFX 2 April 9, 2008 07:40
FSI using cfx and ansys vs ls dyna or dytran HAYATE CFX 1 September 21, 2007 16:11
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
