liquid decreases in bubble column E-E simulation
Old   January 24, 2010, 22:19
Default liquid decreases in bubble column E-E simulation
jhchen is on a distinguished road
Hi, I have a problem in bubble column simulation. the column is 0.1 m in diameter and 2m in height. Initially quiescent water is filled at the lower half. the gas is introduced at the bottom. The top surface is set as pressure outlet. k-eps model(mixture version) and QUICK scheme is used.
Question is: at heigher Ug(>0.1 m/s), the liquid will decrease dramatically, but not because entrainment since I have monitored the flux on outlet.
I guess some convegence problem causes this problem. Possibly the gas cap above the liquid bulk region, the backflow settings about the pressure outlet BC may be potential sticking points.
would u help me? Welcome constructive discussions.
ps: I know the degassing BC and it seems not practical for the simulation with gas cap. I have also extend the simulation domain but it doesn't help.
jhchen is offline   Reply With Quote
Old   August 3, 2010, 11:49
Simon Hans's Avatar
Simon Hans Niemann
Simon Hans is on a distinguished road
Did you set a minumum vf for the liquid phase? In that case your mass balance will not be satisfgied in regeions where vf_liq should go to zero
Simon Hans is offline   Reply With Quote
bubble column, e-e, gas cap, gas-liquid
Turbulent boundary conditions for bubble column anjai FLUENT 12 October 17, 2005 07:34
simulation of taylor bubble merrouche djemai Main CFD Forum 0 December 18, 2002 05:34
compressible liquid simulation kaiser Main CFD Forum 0 October 13, 2002 05:32
Simulation of bubble growth Jean van der Merwe Main CFD Forum 3 May 1, 2001 20:40
Gas Bubbling through Liquid Column marakib FLUENT 0 March 18, 2001 09:19
