Fluent simulation of centrifugal pump
Old   January 20, 2010, 10:44
Question Fluent simulation of centrifugal pump
@p N
yvonne is on a distinguished road
Hi! Im simulating 3 d geometry of a pump having a regenerative impeller. Although the file is read in FLUENT, I'm not able to define the turbo topology for the same. Can anybody help me wid da same???
yvonne is offline   Reply With Quote
Old   January 27, 2010, 02:45
Masashi Ohbuchi
Ohbuchi is on a distinguished road
Did you pressed "Define" button after every boundary-surface setting?
You should only one click after all boundary-surface setting.
And Turbo topology is only applicable to blade to blade pitch domain.
Ohbuchi is offline   Reply With Quote
Old   January 27, 2010, 07:27
@p N
no.. i didnt press define.. but, the problem is.. in the regenerative impeller.. i cant make out what the hub and casing is. Im simulating the entire impeller, so i don have any periodic regions.What should i do??
Old   January 28, 2010, 05:48
Masashi Ohbuchi
Turbo topology of Fluent does not support whole impeller model.
centrifugal pump, fluent
IC engine simulation tutorial by FLUENT yash FLUENT 4 April 6, 2015 20:44
2D Large Eddy Simulation with fluent? Barry Cole FLUENT 4 October 2, 2013 14:36
Centrifugal pump analisys pump_passion CFX 4 July 3, 2009 06:09
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 06:05
boundary condition impeller centrifugal pump mino2006 FLUENT 2 December 28, 2006 19:07
