wild
Rep Power: 16 ![]() |
Hello, guys,
I am trying to simulate an axial compressor to compress a mixture of CO2 and water vapor, but have little idea how to set them up in FLUENT. Basically I know the mixture's mass fraction or Cp(with idea gas density), how can I set it in FLUENT? Any hint would be highly appreciated. thanks. |
alidogrul
I think you can patch both of the fluids before the analysis as an initial condition, and I can say that it doesn't differ you solve it steady or unsteady.
chétan
Rep Power: 17 ![]() |
You can firstly select species from Fluid i.e. CO2 and H2O from Material panel. Then from same material panel create a mixture , add those species in mixture. And finally, you can patch them from solution panel after initialization of your model.
#4 | |
sukhvinder singh
Rep Power: 14 ![]() |
i have to measure the pressure drop in pipe, in this pipe the flowing fluid is a mixture of pulverised coal & air... i am not familiar wid the creation of a new mixture in fluent.. so please help me n reply wid a sequence of steps if this thig is known to you... thanx in advance,, |
hesam
Rep Power: 5 ![]() |
In Eulerian transient model with species transport (non-reaction), I want to make two mixture material phases . From model >> species I selected the mixture template for phase 1 but I am confused how I can make another mixture material (for phase 2). Do I have to select a pre defined mixture form species phase property (like benzene -air ) and then modify it (delete species of pre defined mixture and add new desired species). Is there any other straight way like what I did for phase 1?
Thanks for your time. |
To define Moist Air in Fluent | JW | FLUENT | 7 | April 29, 2015 05:18 |
Wall temperature define in fluent | zdz198728 | Main CFD Forum | 3 | November 19, 2009 00:37 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
To define Moist Air in Fluent | JW | FLUENT | 1 | April 15, 2006 17:31 |
Mixture model in FLUENT 6.0 | Siva | FLUENT | 0 | March 24, 2004 03:39 |
