November 15, 2009, 12:52 |
Fluent on windows server
Hi all
I wan to run parallel fluent with 3 nodes using MS job scheduler. I am using currently Windows Server 2008 with HPC package. It is written in the UG of Fluent that I should use the XML template for submitting my job. Now I have the following issues 1) Do I need to install RSH Daeomon aas we used to do in windows XP case 2) I am sharing ANSYS Inc (as I am using Fluent 12 now in ANSYS) only, do I need to share the subndirectories as well? 3) My path is C:\Program Files\ANSYS Inc\v120\fluent\ntbin\win64, do I need to specify it in the environmental variables? Please help me in this regard |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
On C/C++ Compiler used in FLUENT 12.0 on Windows Platform 64 bit | lzgwhy | FLUENT | 0 | July 23, 2009 05:24 |
Gnuplot and Fluent on Windows | Arianna | FLUENT | 4 | January 25, 2007 11:00 |
Installing Fluent on Server | CAM | FLUENT | 0 | January 12, 2007 20:20 |
Fluent Windows / Linux with AMD X2 dual core | Lohen | FLUENT | 0 | July 28, 2006 10:35 |
