ANSYS to Linux
Like Tree1Likes
Old   March 29, 2010, 16:24
Basharat
elbasharat is on a distinguished road
tel me kishor you have licnd version of ansys 12 ?
elbasharat is offline   Reply With Quote
Old   March 30, 2010, 03:23
Red face
  #22
adminCAE
mechanicaldesign is on a distinguished road
Hi elbasharat ,
How I can observe, your are just like me an curious user which can download ANSYS not for commercense or other financiar interest, but only from your curiosity, to see the new interface, how it works, what is the difference, etc. So, you can send me please on my personal email your site from were you download ANSYS for Linux under 64 biti? Or you can help me with your version ?
I waiting much early is possible your answare.
Thank you for you support.
Best regards.
mechanicaldesign is offline   Reply With Quote
Old   April 2, 2010, 02:59
Red face
  #23
adminCAE
Hi elbasharat,
Fortunatly, I downloaded ANSYS 12.1 Linux 64. Unfortunatly, like in usualy case, the "license" is not valid for the computer where is installed ANSYS. The reason is very simple: the "license" is made in a manner in which can function only on computer on which is made. In this case my option is to use an license which is used on windows platform, and compare it. The modifications must be made on host name and computer number.
The second option is to use an license generator, like for older version of ANSYS.
If you have other ideea, dont hesitate to write me here, or on my email adress: mefeagroup@hotmail.com.
Best regards.
Old   April 2, 2010, 08:01
Lightbulb ANSYS 12 Linux 64 - on Fedora
  #24
adminCAE
Hi all,
Have somebody installed ANSYS 12 LINUX 64 on Fedora ?
I'm curious, because this version of linux is free from Red Hat, and ANSYS is made to work on Red Hat.
I waiting your message reffering to rhis.
Best regards.
Mess with the best die like the rest ... ANSYS is the best !!!
Old   April 2, 2010, 16:14
Question
  #25
adminCAE
Hi to all,
Finaly I install the ANSYS 12.1 beta Linux 64 on laptop. The license it was generated using license generator from ANSYS 12 WIN 32. To install the license I used wine software. Everything works fine, and I launch the Launcher panel, where I settup :
- Simulation Environment : ANSYS
- License : ANSYS MULTIPHYSICS / LS-DYNA
After that I run ANSYSLIC_ADMIN where I restart the License Manager and I Reread the license.
Everything works fine, but after I push to ¨Run¨ button, I obtained the next error:
Feature: ane3flds
FLEXnet Licensing error: -25,147
I waiting much early is possible your suggestion or some help.
Thanks in advance for support and advice.
Best regards.
Old   April 22, 2010, 10:11
Basharat
I have done this.. tell me again what you want.. and also check your email inbox.. i have sent you email.....
cheerssssssssssss
martin
Old   April 30, 2010, 05:14
Exclamation
  #27
Martin
marbro is on a distinguished road
Originally Posted by mechanicaldesign View Post
Hi to all,
Feature: ane3flds
Best regards.
Hi all
I have the same problem as above. Last time I installed ansys 12.1 and all works great to time when I connected to internet where server stopped working . When I work without internet it works great but in connecting with internet I have similar message as above.
Anybody help me
Greetings
bross
marbro is offline   Reply With Quote
Old   April 30, 2010, 05:20
Basharat
dear.....
i have run eve ansys 12.1 linux 64 bit and it is not beta version...
just you tell me that your flexlm is running in your lic manager windows?
just tell me this thing only...
cheers
martinnnnnn
Old   April 30, 2010, 05:47
Martin
Ok I work on Windows 7 32bit and Ansys 12.1.
I return to you for help. Last time I installed Ansys 12.1, everything works great to time when I try to connect to internet when server show me that is problem and doesn't work. In Task Manager I saw that ansylmd.exe has too high using CPU 50%. OK I turn out internet and turn on one more time ansyssli_server and Ansys works great. When I turn on internet I try to lunch Ansys it show me that something wrong with license.
And I don't know what can I do.
Thank for help
Old   April 30, 2010, 06:03
Basharat
dear friend.. I dont know why you have this problem with you over windows environment... I m only here for linux that is really big issue for the most linux users over CFD...
anyways... have you got ansys 12.1 windows 32 or 64? and including it has lic generator also. you should reinstall your windows and then install ansys again. i wil work fine.. and whenever you run ansys you should close your network card or connection.
tell me if you are concerned with linux... have you got any info regarding ansys over linux????
and and you can easily download win softwares but never linux's...
Old   April 30, 2010, 06:16
Martin
Ok I have ansys 12.1 and windows 7 32bit (Magnitude with license generator). I can't reinstall my windows because I have more programs and now I'm working on project to my work connecting with mechanical contact. I think that issue was easy to solve
previously I have ansys 12 and works great I haven't any problem with it. I read on other forums and people and complain of this problem but I haven't seen any solution.
Old   April 30, 2010, 07:40
Basharat
i think you should close your lmgrd service thre restart it... or better to uninstall your ansys whole setup and reinstall it
llllllllllllllllllllllllllllll
cheers
martin
Old   April 30, 2010, 08:04
Martin
I done everything restart lmgr.exe, than twice I reinstalled ansys and nothing the same problem. I cleaned environment variable before installing. I'm thinking now about register.
Ok but thanks mate for help
Old   April 30, 2010, 09:52
Basharat
yeah.. delete from registry also... and
and
i saw your processes... you dont have smpd service also.... even though your processor is consuming in lmgrd service.
Old   April 30, 2010, 12:44
Martin
ANSYS reinstallation didn't help and cleaning from registry. After to internet connect I have this message:
Old   April 30, 2010, 14:25
Basharat
dear friend....
do you have pirated software of ansys?
Old   April 30, 2010, 14:58
Martin
on academic license from my university
Old   May 11, 2010, 09:13
Unhappy
  #38
adminCAE
Hi marbro,
In this moment I think is about the version of ANSYS which you have installed on your computer. I used ANSYS 12 on Windows 7 64bit, and works very well, and I am linked to internet too.
From my experience, after I read some problems with diverse forums, I sugested (unfortunately for you) to reinstall your windows, blocked firewall and all other security programs, and after that reinstall your ANSYS ( if is original version from your faculty, etc). If you have obtained ANSYS from download (from torrents), that means from your version mess something.
I'm sorry because my sugestion don't help you in some manner.
If you resolve your problem without reinstallation of windows, please posted here the manner in which resove it.
Best regards.
Old   May 25, 2010, 04:24
Default ANSYS to Linux
  #39
mark
mark.richard is on a distinguished road
i try to install ANSYS ( ANSYS 12) on Linux SuSE Enterprise 10...but faces some problems.....have somebody installed on it .....please help me in that ....thanks
Ezine
mark.richard is offline   Reply With Quote
Old   November 29, 2010, 18:30
Default ANSYS 12.1 64 bits on unbuntu 10.10 64 bits
  #40
belamou
donminoti is on a distinguished road
Hi all,
I'm trying to set up ANSYS 12.1 64bits on ubuntu 10.10 ,64 bits . i've done the installation ,but when i try to lauch CFX_PRE ,it displays a license error message .
"Feature CFX_PRE does not exist in the ANSYSLI pool." .
Any help would be great. actually i'm new on Linux !!!!
Thanks .
donminoti is offline   Reply With Quote
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
Command Line Run for ANSYS Liaquat ANSYS 11 April 19, 2018 10:49
How can I start the ANSYS 12 workbench in LINUX Ardisia ANSYS 3 September 7, 2010 01:19
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
How to set font size of Ansys GUI on Linux? Field CFX 1 July 31, 2006 02:06
