Saving *.cas and *.dat from parallel version
Old   August 14, 2009, 14:31
Default Saving *.cas and *.dat from parallel version
Pfalcon is on a distinguished road
I am experiencing problems when I'm saving the case and data file from the parallel version (FLUENT6.3). These files are incompatible with Tecplot360. When I load the case into the serial version of FLUENT and resave it, Tecplot reads them just fine.
Same problem when I use FILE-EXPORT function to create TECPLOT files from the parallel version. The files are almost always corrupted.
Does anyone have a fix for this?
Many thanks in advance
Pfalcon is offline   Reply With Quote
Old   August 15, 2009, 09:18
abdul samad
samad87 is on a distinguished road
does it work when u resave the cse n data files in normal fluent window
samad87 is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
UDF in parallel version of fluent yobee FLUENT 2 August 5, 2004 01:36
Parallel version Nikolay FLUENT 2 October 10, 2002 04:42
Parallel STAR version Michael Schmid Siemens 1 November 7, 2001 10:41
Parallel version of SIP ? Ravikanth Avancha Main CFD Forum 1 March 19, 1999 15:21
