Turbulent Model Problem
Old   July 31, 2009, 22:03
Default Turbulent Model Problem
King
yeeking86 is on a distinguished road
I am running simulation on micro-scale model. The Re is really low (bout 50) so which turbulent model should I be using? Or should I just use None?
Thank you
yeeking86 is offline   Reply With Quote
Old   September 30, 2009, 11:40
Tim Maguire
timjm is on a distinguished road
When I was simulating microfluidic devices at low reynolds numbers I just left the turbulent model off.
Only put it on if you forsee having turbulent flow i.e. high reynolds numbers.
timjm is offline   Reply With Quote
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 17:01
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 14:40
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM varghese FLUENT 6 February 6, 2002 06:23
Turbulent model in 2D calculations Francisco Saldarriaga Main CFD Forum 1 August 11, 1999 00:10
