How to slove "temperature limited to 1.0000e+00001 in cells.." |
September 15, 2021, 06:25 |
Temperature limiting error
#21 |
Rep Power: 6 |
Hello
I have had the same problem with some of my models. However, my global solution is affected by even one cell reporting this problem. I have had to redo the simulation/grid until the error is not reported at all. Is this something which has affected others too? I read earlier that if it's just one cell then you can ignore it. But my global solution seemed different in the 2 cases. Any ideas on this? Thanks |
January 11, 2024, 04:05 |
#22 | |
Yakub
Rep Power: 3 |
For adapt mesh make cell register in adapt---->Manual--->cell register. Better to see video about cell adaption. Dont follow the videos using ansys fluent older than 2011 version, because older one had iso value adaption, now it is removed from fluent. |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
How to deal with "Temperature limited to 1.000000e+000... | Conan | FLUENT | 0 | April 7, 2009 02:40 |
reversing flow | Martin | Siemens | 14 | March 18, 2009 09:07 |
Temparature is limited to 1.00000 in 19879 cells.. | srinivas | FLUENT | 19 | February 14, 2006 02:12 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
