mesh of pipe with branchs
Old   July 3, 2009, 01:41
Default mesh of pipe with branchs
afm
cfdlover is on a distinguished road
hello all;
I'm trying to mesh a cylindrical pipe which is 20 cm long, 2 cm in diamter (its axis is in x direction) and at the middle of the pipe, there are two branches, on in y direction and the other in z irection, i.e., the brances and the tube are perpendicular to each other.
I need help to creat the mesh.
Thank you.
CFD- LOVER
cfdlover is offline   Reply With Quote
Old   July 9, 2009, 11:05
Michael P. Owen
michael_owen is on a distinguished road
What tools are you using? What problems are you running into? Most importantly, how do you expect to get any help asking a question like this, with almost no information?
michael_owen is offline   Reply With Quote
Old   July 9, 2009, 11:41
Edgard Espinosa
eespi002 is on a distinguished road
Are you trying to mesh the inside of the pipe or the outside?
eespi002 is offline   Reply With Quote
Old   July 10, 2009, 12:58
afm
hello;
im using GAMBIT. There is flow coming from one branch and it distributes to the main tube and the other branches. How can I split these volumes to create cooper or any other high quality mesh?
Old   July 10, 2009, 14:37
Edgard Espinosa
I still consider my self a beginner with Gambit/ Fluent. What I have been doing meshing the surface with a tri-pave mesh. I do my best to ensure it has a great skewness score. Also on the inlet and outlet. With that, I hope when I generate a volume mesh, maintain good quality. Tri/tet mesh where meant to tackle difficult contour like pipeline branch off and splits.
Try it. I hope this helps.
Old   July 10, 2009, 17:16
John is on a distinguished road
Originally Posted by cfdlover View Post
hello;
Tutorial 1 of Gambit should give you some ideas of doing this. Basically you need to split the whole domain at connection location, which results in three volumes. And each volume should share two faces. Meshing the shared faces first and then you will get hex mesh for all three volumes
John is offline   Reply With Quote
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 13:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to draw pipe mesh Ismael FLUENT 2 March 3, 2007 17:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
stuctured mesh 4 a y pipe toni Main CFD Forum 2 October 17, 2001 13:51
