Modeling Heat Flux using FLUENT
Old   May 20, 2009, 09:43
Default Modeling Heat Flux using FLUENT
Ankur Gahlot
ankurgahlot is on a distinguished road
I am trying to model a solar collector (using air as fluid) in FLUENT. Right now I am giving a constant temperature to the collector plate and using that to get the air flow pattern.
I want to make it a bit more realistic and use heat flux in place of the constant temperature. The energy at the earth's surface from the sun is available in solar data. So, I am giving it a heat flux of around 700 w/m2.
But the temperature reached in this case is around 400 - 500 kelvin which is unrealistic.
Currently I am using boussinesq approximation and laminar flow.
What else do I need to include in this ?
Could anybody please help me with this.
Thanks
ankurgahlot is offline   Reply With Quote
Old   April 18, 2013, 04:46
Laura
laura_c is on a distinguished road
i am experienceing the same problem... but i m using ideal-gas modelling... how did you manage to solve it? thanks
laura_c is offline   Reply With Quote
Old   April 20, 2013, 11:17
dklastiwka's Avatar
Derek Lastiwka
dklastiwka is on a distinguished road
We would need more information to solve the problem. Can you send the model and give the reference for the heat flux of 700 W/m^2?
Derek Lastiwka
Mechanical & Fluids Engineer
dlastiwka@graymattereng.com
Gray Matter Engineering Inc.
dklastiwka is offline   Reply With Quote
Old   September 25, 2013, 16:14
miguel
miguel.soto is on a distinguished road
Iīm dealing with a similar issue as ankurgahlot and laura_c.
My case is a forced convection heat transfer, for an alternator cooling. The alternator heat flux to the surrounding air is 1050 W/m^2, and the upstream air velocity is set as 15m/s. The alternator boundary thermal conditions are set as heat flux (I also considered to set thermal conditions as temperature, but alternatorīs temperature is what iīm trying to know).The solution convergence is acceptable, but the alternators temperature solution is too high, it reaches 5000 K, this value is out of context. The experimental test data shows that the maximum alternator temperature is around 373 K.
does anybody knows what we are doing wrong?
Thanks in advance
miguel.soto is offline   Reply With Quote
convection, fluent, heat, heat flux, thermal
Calculation of heat generation in Fluent for 2D krishnachandranr FLUENT 0 April 8, 2009 00:31
Wall Heat Flux not a listed variable mike CFX 8 February 5, 2009 14:32
how to export "wall heat flux" to tecplot? victor CFX 3 November 27, 2008 10:45
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
solar heat flux through roof Tim FLUENT 1 January 17, 2007 17:01
