Can segregated solver be used for compressible flow?
Old   May 14, 2009, 11:37
Default Conjugate heat transfer of turbine blade
Steven-GY is on a distinguished road
Hi Fluent user friends,
I am encountering a convergency problem using Fluent solver to solve a subsonic turbine flow. The application is a conjugate heat transfer involving solid blade, mainstream compressible flow (M0.5-M0.9) over the blade surfaces and incompressible low speed cooling air passing through the inside of blade. I always have the convergency problem for both coupled and uncoupled solvers. Does anybody have experience of this complex conjugate heat transfer which have two different fluid domains, one is compressible and another is incompressible? Any hint would be helpful to guide me.
This is how I did. Density-based solver. Ideal gas law is used to obain the density of compressible mainsteam flow, while incompressible ideal gas law is applied for the cooling flow. Periodic BC was applied in the sidewalls of computational domain. Pressure inlet and outlet boundary conditions were used for both flows. Standard KE Turbulence models are applied.
Thank you very much in advance.
Steven
Steven-GY is offline   Reply With Quote
A role of combustion modeling in flow solver? Yoon Main CFD Forum 0 November 26, 2006 13:00
Convergence Definition of Segregated Solver Amir FLUENT 0 April 18, 2006 07:21
Inviscid solver : separation of the flow Jean-Marie Cavet FLUENT 1 September 2, 2003 13:32
Free 2D Axisymmetric Potential Flow Solver for Matlab? Jonas Larsson Main CFD Forum 0 August 13, 2003 10:13
Incompressible flow solver (staggered grid) J. Ehrhard Main CFD Forum 1 October 8, 1998 20:47
