November 29, 2024, 03:40 |
Ansys EMtoIcepack issue
Ilya
Hello everyone! Im trying to do a two way coupled electrothermal analysis in AEDT using ACT extension "EMtoIcepack". As far as I understand, I have to manually set temperatures in HFSS to be able to do so. But when Im trying to set temperatures in HFSS -> Set Object Temperature..., I cant modify values, and if I press "Set default", value modifies to 22 cel., but HFSS doesnt save the changes for some reason. How can I save those changes to make the analysis work?
Any lead/guidance on above issues will be highly appreciated, thanks! |
ansys, electrothermal, emtoicepack, hfss |
Yes, some codes could be better than ANSYS | Dr Youssef Hafez | ANSYS | 0 | January 13, 2023 12:41 |
ANSYS, GUI Startup Issue | utengr | ANSYS | 0 | October 4, 2017 01:11 |
[ANSYS Meshing] sweep meshing issue ansys 18.0 | CeesH | ANSYS Meshing & Geometry | 8 | August 25, 2017 09:05 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 07:44 |
Ansys Workbench Issue | umer100 | ANSYS | 0 | May 16, 2013 09:38 |
