Today, 12:24 |
Turbomachinery ICEM Meshing
Sakun
Rep Power: 7 |
I am meshing a compressor blade/domain using ICEM. Crated the 2D geometry and ran some good simulations. Now I have to do the same procedure for the 3D geometry as well. So, I have extruded the 2D geometry and blocking. Then did the blocking association to edges then associated faces to surfaces as well. But BACK surface some areas are not align with FRONT face. I have check pre-mesh quality and there is nothing wrong with them. Can someone help me on this issue ? Thanks for your time |
icem, turbomachinery |
[ANSYS Meshing] SHIP MESHING * using ansys WORKBENCH or ICEM CFD | Ctunramran | ANSYS Meshing & Geometry | 1 | February 23, 2016 08:06 |
[ICEM] ICEM Meshing Beginner facing problem importing file. | rrahman | ANSYS Meshing & Geometry | 0 | September 2, 2015 15:18 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
[ANSYS Meshing] Issues in exporting mesh from Meshing to ICEM CFD | sihaqqi | ANSYS Meshing & Geometry | 5 | March 5, 2013 03:40 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 11:09 |
