November 20, 2024, 11:09 |
Ansys automation
AOH
Hello, I am working on automating ANSYS with MATLAB. First, I create a .bgi file, which I then convert to .bgd using BladeBatch.exe. Afterward, I want to automate the BladeGen-TurboGrid-CFX process using a journal file, but I’m encountering the following issues:
When I modify the bgi file I adjust the theta angle distribution, but I also want to control the starting beta angle at the leading edge. Does anyone know how to impose this condition from the bgi file? Once I have the bgd file, how can I incorporate it into the process defined in the journal file that I execute with RunWB2.exe? Which option is better for automating the process: using the journal file or running each program separately with its respective executable? Thanks and best regards! |
ansys, automation, bgi, workbench |
Yes, some codes could be better than ANSYS | Dr Youssef Hafez | ANSYS | 0 | January 13, 2023 12:41 |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 13:11 |
[ANSYS Meshing] ANSYS mesh - I was surprised... | assafwei | ANSYS Meshing & Geometry | 0 | September 4, 2014 13:17 |
Ansys HPC licensing policy | assafwei | ANSYS | 0 | June 29, 2014 17:00 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 02:10 |
