Help with modeling flow over sealed enclosure
Old   November 4, 2024, 08:05
Default Help with modeling flow over sealed enclosure
Su
hyeunsu is on a distinguished road
Hello!
I am a mechanical engineer and recently I have been working with more CFD but most of my knowledge has been from Youtube videos and university years ago. The past half year or so I have been reviewing and practicing on ANSYS Fluent and CFX and can do relatively simple problems with no problem.
However, I can't seem to figure out how to set up and run (getting good results) this problem.
I have a completely sealed electronics box with components inside. The system consists of 5 copper chips each generating about 50W of heat, attached to a PCB board, which is attached to a backplane. The heat inside of the box is transferred through the chassis by conduction and natural convection to then be cooled by forced convection of air flowing over the box.
I have tried setting up with laminar flow with an enclosure around the closed box with inlets in the sides of air (0.05 m/s) and outflow outlet. I have also tried with filling in the air within the sealed box as a seperate fluid (air) and I seem to have problems with starting Fluent or getting unrealistic results (such as 4000K).
If there is any guidance or comments please let me know! Thank you!
hyeunsu is offline   Reply With Quote
ansys, cfx, fluent
Modeling the gas flow through the packed bed of DEM particles Legat STAR-CCM+ 6 January 17, 2024 09:58
actual flow rate not match the designed flow rate in ventilation modeling minecraftgp OpenFOAM Running, Solving & CFD 2 November 18, 2018 13:37
Viscoelastic flow modeling in rotorstator system vulda OpenFOAM Running, Solving & CFD 4 December 25, 2017 04:01
mold flow modeling Pei Hsieh Main CFD Forum 0 May 4, 2005 11:08
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
