The impinging jet is rolled up in Polydata
Old   October 25, 2024, 12:27
Default The impinging jet is rolled up in Polydata
Vu Tuan Khanh
vutuankhanh is on a distinguished road
https://youtu.be/tbnGK_DYcos?si=7Kn5PpL9zb3xl716
Dear everyone,
This is not a question but a sharing post. I encountered a rather interesting error when simulating in ANSYS Polyflow. My simulation problem is a 1-nozzle jet hitting a flat surface. The fluid used is water. The Reynolds number of the flow is 3,000. The error only occurs when the model mesh is very small.
Error analysis:
- Vortex formation after collision: At Re = 3,000, the flow is in the transition zone between laminar and turbulent flow.
- Transient simulation: The vortices in transients are the result of the flow changing over time. When the jet hits the surface, the energy of the flow is not immediately dissipated, leading to temporary local vortices.
Solution:
Convert transient simulation to evolution simulation: In evolution simulation, the process is not simulated over time, but Polydata gradually changes the parameters (density, thermal conductivity, heat capacity of mass, ...) from the initial state to the steady state. Helps eliminate oscillation phenomena such as vortex when the flow reaches a steady state.
This is really not recommended because ANSYS Polyflow can only simulate laminar flow and when you simulate with high Reynolds number, you will not get accurate results.
Hope this sharing is helpful to everyone
Regards,
Vu Tuan Khanh
vutuankhanh is offline   Reply With Quote
polyflow;
AxiSym laminar impinging free surface jet Kinrah OpenFOAM Running, Solving & CFD 1 December 26, 2016 07:11
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 21:18
impinging jet natesan Main CFD Forum 3 March 17, 2005 06:42
impinging jet natesan Siemens 1 February 25, 2005 04:16
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 23:11
