When the fluent has the below problem, it cannot be saved or do any other operation? |
Rep Power: 9 ![]() |
When the fluent has the below problem, it cannot be saved or do any other operation? What is the reason? How to solve it?
Information: The surface name wall no longer exists for report definition heat-01. They must have been deactivated/deleted.Surface groupings have changed. This has resulted in surface list selection changes for the following report definitions. heat-001 [mpiexec@DESKTOP-6NL2RP5] ..\hydra\pm\pmiserv\pmiserv_cb.c (863): connection to proxy 0 at host DESKTOP-6NL2RP5 failed [mpiexec@DESKTOP-6NL2RP5] ..\hydra\tools\demux\demux_select.c (103): callback returned error status [mpiexec@DESKTOP-6NL2RP5] ..\hydra\pm\pmiserv\pmiserv_pmci.c (520): error waiting for event [mpiexec@DESKTOP-6NL2RP5] ..\hydra\ui\mpich\mpiexec.c (1149): process manager error waiting for completion The fl process could not be started. ———————————————— |
Stefan problem using fluent | Isaacibp1401 | Fluent Multiphase | 2 | June 7, 2021 05:49 |
Strange Mesh Problem in Fluent | alpcfd | FLUENT | 1 | October 8, 2020 12:47 |
Problem with Volumetric Reactions in Fluent | Kashif Rashid | Fluent UDF and Scheme Programming | 2 | December 28, 2017 00:36 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 20:08 |
