赵赫(Zhao He)
Rep Power: 0 ![]() |
Hello everyone, I have encountered an issue while using bidirectional fluid-structure coupling simulation. After updating the settings in the fluid module and transient module, the system coupling module fails to enter the settings for fluid-structure coupling. The specific error is:
(DP 0) The Setup component in System Coupling requires user input before it can be updated. Edit the System Coupling Setup cell, then right-click on any ? in the Outline tree, and select "Display Validation Failure" for more details. How can I solve this problem?:困惑: |
赵赫(Zhao He)
I solved the problem in a weird way by changing the initialization method from standard initialization to mixed initialization, but I still don't understand the reason behind it.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
