DP Pham
Rep Power: 2 ![]() |
Dear all,
I am dealing with SLM process, I get problem that when the laser irradiate on the powder, the iso-surface moves up as I shown in the figure. Does anyone have any advices to solve this problem? Thank you all. |
Marcin
Rep Power: 13 ![]() |
Iso-surface movement during SLM simulation in ANSYS can be caused by several factors. Here are some potential causes and solutions to consider:
* Inaccurate Melt Pool Dynamics: The melting behavior of the powder might be misrepresented in your simulation. Calibrate your material properties, laser power settings, and melt pool viscosity to better reflect reality. * Meshing Issues: A coarse mesh might not capture the melt pool dynamics accurately. Refine your mesh, particularly around the laser-powder interaction zone, to improve precision. * Unstable Time Stepping: Large time steps can lead to numerical instability and inaccurate results. Reduce the time step size in your simulation for better stability. * Evaporation Modeling: If your simulation includes evaporation effects, ensure the evaporation rate is set realistically to prevent excessive removal of material. By carefully examining these potential causes and implementing the corresponding solutions, you can improve the accuracy of your SLM simulation and address the issue of iso-surface movement. More at link below https://howtooansys.blogspot.com/202...eshooting.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
DP Pham
Thank you for your kind help.
fluent, slm |
Making an iso surface act like wall for reflection | Jazz | FLUENT | 1 | June 10, 2022 06:52 |
How to calculate the volume of a clipped iso surface | Roscoe341 | Fluent Multiphase | 0 | June 17, 2021 08:20 |
location of iso surface or iso clip | Aashi171185 | CFX | 1 | May 7, 2019 18:24 |
iso surface in Openfoam | farensheep | OpenFOAM | 3 | June 24, 2017 14:58 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
