Fluent UDF for Radial Motion of Pump Geometry |
June 7, 2024, 10:10 |
Syaida
I'm currently working on a 2D simulation in Fluent that requires me to simulate the radial motion of a pump geometry. To achieve this, I've implemented a UDF (User-Defined Function) for grid motion, which aims to change the radius of the pump geometry over time and return it to its original radius after a specified duration (to replicate inflation and deflation of the balloon pump).
I've encountered an issue where the pump geometry shifts laterally (to the right or left) instead of the intended radial motion. Below is the UDF code I'm using for the grid motion: #include "udf.h" #include "math.h" DEFINE_GRID_MOTION(pump_wall_motion, domain, dt, time, dtime) { Domain *d; Thread *t; face_t f; Node *node_p; real current_time = CURRENT_TIME; real final_radius = 154.94e-3; real original_radius = 230.74e-3; real transition_duration = 2.0; // Duration of the transition in seconds real transition_speed = (final_radius - original_radius) / transition_duration; // Speed of transition real center_x = 141.05; // X-coordinate of the pump center real center_y = 5.0; // Y-coordinate of the pump center int n; // Calculate the new radius based on the linear transition real new_radius; if (current_time < transition_duration) { new_radius = original_radius + transition_speed * current_time; } else { new_radius = final_radius; } // Get the domain and thread d = Get_Domain(1); t = Lookup_Thread(d, 9); // Iterate over all faces in the thread begin_f_loop(f, t) { f_node_loop(f, t, n) { node_p = F_NODE(f, t, n); if (NODE_POS_NEED_UPDATE(node_p)) { NODE_POS_UPDATED(node_p); // Get current coordinates relative to the center real x = NODE_X(node_p) - center_x; real y = NODE_Y(node_p) - center_y; // Calculate the distance from the center real distance = sqrt(x * x + y * y); // Prevent division by zero for nodes exactly at the center if (distance > 1e-6) { // Calculate the scale factor based on the new radius real scale_factor = new_radius / original_radius; // Calculate the new position real new_x = center_x + x * scale_factor; real new_y = center_y + y * scale_factor; // Update node positions relative to the center NODE_X(node_p) = new_x; NODE_Y(node_p) = new_y; } } } } end_f_loop(f, t); } I've already tried verifying the centre coordinates, thread selection, boundary conditions, and mesh quality, but the lateral motion issue persists. Any insights or suggestions on resolving this issue would be greatly appreciated. Thank you! |
pump simulation, udf |
Fluent UDF Mesh Motion Issue: Blade Pitch w/ Respect to Azimuth Angle | recmvp | Fluent UDF and Scheme Programming | 0 | July 30, 2023 15:50 |
Specifying Mesh Deformation & Rigid Body Motion on a Cell Zone Using UDF | zx9cp | Fluent UDF and Scheme Programming | 3 | July 11, 2023 05:14 |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 9, 2022 23:58 |
Define grid motion udf issue: Wing geometry breaks down with time | tev_lev | Fluent UDF and Scheme Programming | 0 | June 1, 2022 11:22 |
Zone motion udf error in Fluent | Sigurd | Fluent UDF and Scheme Programming | 9 | November 30, 2020 02:34 |
