Need help about simulation time in Forte (Fluxing Volume) |
April 20, 2024, 10:27 |
Chor.chayangkoon Somsin
Hi! I am working on my senior project on H2 combustion in ICE. I use Ansys Forte 2021 R1 Student to simulate the combustions by the use of H2 fuel. Right now, I am working on the tutorial given by Ansys itself. The name of the tutorial is Hydrogen Combustion. However, I encounter something that I cannot resolve and wish to ask for helps.
Right now, I am simulating my engine from IVC-EVO. I modify the set-up from the tutorial slightly (I change Chemistry mechanism). I find that it takes extremely large amount of time to process in each crank angle. I observe that the time constraint is always 'Fluxing Volume' in the Monitor Runs panel. I find this situation kind of strange. The reason is that I tried to run the simulation with the this set-up before. During that time, I did not modify anything. It appeared that the simulation was pretty fast during IVC-EVO. However, the slow down happened, but happened approx. after 200 deg ATDC, which was the CA that I could ignore. I do not know the reason for what I have mentioned, and the way to solve it. Your help is greatly appreciated! |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Simulation crashed shortly after it started | ce73stargazer | OpenFOAM Running, Solving & CFD | 0 | September 2, 2016 00:16 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
