Ren Yongpeng
Rep Power: 0 ![]() |
Hello everyone, I am using FENSAP-ICE to calculate icing. Currently, it is necessary to change the liquid characteristic parameters to simulate the icing laws of different types of liquid. Fluid properties can be modified in the ice 3d of FENSAP-ICE. But there will be errors after calculation. Can this problem be solved by modifying the FENSAP-ICE input configuration parameter code, or is there any other way to solve it? Thanks a lot.
WechatIMG181.jpg WechatIMG180.jpg[/ATTACH] |
fensap-ice, fluid properties |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
fluid fluid radiation properties | IronLyon | CFX | 5 | March 18, 2019 16:40 |
Fluid properties as function of Temperature with polynomial using chtMultiRegionFoam | qferon | OpenFOAM | 1 | November 3, 2018 13:41 |
Why i need to material properties before fluid draw into the tube in CFD? | fruitkiwi | Main CFD Forum | 10 | April 3, 2012 07:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
