Getting a non zero lift coefficient for a simetric arifoil at 0 degrees AOA
Old   January 8, 2024, 19:03
Question Getting a non zero lift coefficient for a simetric arifoil at 0 degrees AOA
TomTheEngineer is on a distinguished road
Hello, everybody.
I've been trying to model a 2D (obviously) airfoil in Ansys. Since this was my first time with this software, I followed a YouTube video (https://www.youtube.com/watch?v=nzvE...annel=AnthonyT) of a guy that does the same thing only with another airfoil (non symmetric one). The thing is that I do exactly everything the guy does, but yet the results are wrong. I get a 2.36e-3 lift coefficient (about 2.7 N of lift force) when I should be getting at least something smaller (e-6, for example).
I have checked the geometry, mesh and setup multiple times. I even started from scratch several times, yet I get the same results time and time again.
My mesh is totally symmetric (image attached) and the y_plus requirements are met (I get a 0.5 max y_plus, check the results image attached). I am using the k-omega model for turbulence. My velocity is 43.8m/s at 0 AOA, fluid is air, obviously (rho=1.225 kg/m^3 and mu=1.7894e-05 Pa s).
I have also tried other AOA and the results are wrong too, and it is not close (I compare my CFD results with experimental data).
What can I do?
Thanks in advance!
P.S I hope I have provided enough info. If not, lmk.
TomTheEngineer is offline   Reply With Quote
airfoil 2d, lift and drag calculation
Airfoil Coefficient of Lift and Drag - Published Data vs CFD Results Mick2450 CFX 4 April 23, 2020 20:18
Fluent 19.0 Lift and Drag Coefficient Monitors TeriSerugi FLUENT 0 February 6, 2019 18:21
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
Wrong Drag and Lift Coefficient when changing AoA inspiron FLUENT 1 November 27, 2013 14:00
