Negative volume mesh detected in Dynamic Mesh |
November 23, 2023, 09:07 |
Davide
Rep Power: 3 |
Hi everyone,
I am running a two-way Fluent-Mechanical simulation of a shelf (100x3x200mm; xyz) immersed in a tank (300x500x300mm; xyz) filled with a liquid and a gas using VOF method. The tank is subject to the force of gravity and a harmonic force acting along the x-axis with a frequency f=2Hz. Since I wanted the liquid to be initialized with an angle of 10° I have created a region register with cylinder shape with the coordinates shown below. The other settings are shown below as well. When I launch the analysis it stops at a certain time step for "Negative cell volume detected". I have tried to reduce the time-step but it stops even earlier in the simulation. Furthermore, looking at force report (from Fluent) and displacements report (from Mechanical) I have noticed that in the time step that leads to the error, the force and the displacements increase inexplicably and I am not understanding the reason if everything is going well until that time step. To visualize the cells with negative volume I have created a volume register and a iso-surface.
Feel free to ask any other information that you may need. Thanks in advance. |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
[ANSYS Meshing] Small mesh error: Zero or negative volume for elements. [Explicit dynamics] | matin | ANSYS Meshing & Geometry | 0 | September 14, 2017 20:19 |
Negative cell volume detected, dynamic mesh | tony25800 | FLUENT | 6 | September 17, 2014 19:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
