Design Point Table giving identical results for Outputs |
Martin Beer
Rep Power: 0 ![]() |
I am creating a CFD simulation with parameterized geometry. The following problem arose: If I change individual design points manually, the simulation runs smoothly and Post outputs the corresponding values.
If I load several design points into the DP table and update them all, Ansys delivers the same result for the output parameters for each individual geometry. Even the previously manually calculated points no longer give the same result as before. It seems that the solution of the first design point is applied to all design points. Has anyone already had this problem and knows a solution? |
ansys workbench19 |
Component update can be performed only in base design point | Domenico83 | CFX | 0 | March 10, 2017 05:48 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
Importing previous results as a starting point for future simulations | mcintoshjamie | FLUENT | 1 | November 15, 2009 06:38 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
transient results in table viewer | Andrew Fine | CFX | 2 | December 15, 2005 23:39 |
