Garrett Kirk
Rep Power: 0 ![]() |
Is it possible to control the temperature of the additional mass added by a UDF mass source? I conducted a basic test scenario, and it appears that the UDF mass source adds new mass at a constant temperature of 298.15 K. However, I was unable to modify the temperature. The only way I can think of is to add a heat sink UDF to the same domain that removes enough heat to cool the new mass to the correct temperature (21 K). This does not work as intended and instead cools the nearby region. Is it possible to change/set the temperature of the UDF mass source without the use of additional UDFs?
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
