Cracking in concrete
Old   August 30, 2023, 04:22
Default Cracking in concrete
Patricia S
Patricia S is on a distinguished road
I'm modeling a shear-tension two-sided edge-influenced shear stud connection in reinforced concrete (longitudinal and stirrup reinforcement) and would like to determine the crack pattern in the concrete. I have done it so far with the user-defined result "EPTO" (total tensile strain), but the crack pattern shows the concrete edge break a bit too small. Is it allowed to show the crack pattern also with the result "Maximum principal stress"? For this purpose, I have set the limits -25 and +2.2 MPa for a C20/25 concrete. The crack pattern is more in line with the Eurocode 2-4.
Thanks a lot
Patricia
Patricia S is offline   Reply With Quote
concrete, crack, epto, maximum principal stress, shear
When to use solid65 for concrete in ANSYS Workbench (for which type of loading) mirghani Structural Mechanics 1 December 27, 2017 05:52
Ansys Workbench Fracture and Cracking Behavior using Solid65 jackhero Structural Mechanics 0 December 25, 2017 01:45
Ansys nonlinear concrete and frp rod Paolo Palari ANSYS 0 June 10, 2013 07:38
Heat Transfer from airflow to concrete Mary2788 FLUENT 1 June 22, 2011 11:43
Concrete flow in a mold Jihwan Siemens 0 June 2, 2005 02:57
