Is this alternative meshing correct?!
Old   July 30, 2023, 12:02
Default Is this alternative meshing correct?!
Jack
AnsysNewbie is on a distinguished road
I am new to ANSYS so I was thinking which of these two meshing and techniques is more correct: If you follow the instructions by “DrDalyO” in his video, you will use MultiZone mesh which in turn Convergence will not be allowed in it as I have used.
In his example “DrDalyO” gets a final equivalent stress result of approximately 500 MPa and calls it "very good" while I get an approximately 600 MPa.
Also it seems his meshing quality is not that high.
So which of these methods is more correct and why?
by “DrDalyO:
https://www.youtube.com/watch?v=WJxa-m4hkEA
by me:
https://www.veed.io/view/5d5b7279-65...c3?panel=share
AnsysNewbie is offline   Reply With Quote
Prism layer meshing to get correct Y+ surajp92 STAR-CCM+ 9 June 8, 2017 03:33
Meshing Process sidharth9426 STAR-CCM+ 4 September 15, 2015 04:31
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 13:45
