Parameter stepping in coupled analysis
Old   June 15, 2023, 16:11
Default Parameter stepping in coupled analysis
LuciusThorne
LuciusThorne is on a distinguished road
arameter stepping in coupled analysis - I aim to perform a simulation involving a Peltier module that is cooled by a water radiator on its hot side. The cold side consists of a PCB enclosed in a metal case with air.
To model the Peltier module, I utilize the Thermal-Electric solver, while other components are simulated using Fluent.
When I set up an electric current through the Peltier module and initiate water flow in the radiator, the system operates effectively, producing a realistic temperature distribution.
However, I encounter a problem when attempting to step the current from 0 amps to 1.5 amps in increments of 0.1 A. I configure this parameter stepping in the Thermal-Electric solver, defining 15 steps with tabular current data. In the coupled analysis settings, I also set 15 steps. As for Fluent, I couldn't find any relevant settings, so I left them unchanged.
After completing the simulation, I obtain 15 results, but approximately half of them appear highly unrealistic. I am uncertain about the cause of this issue. Is it possible to conduct such simulations in Ansys? Are there any additional settings I need to configure for accurate results?
LuciusThorne is offline   Reply With Quote
Flutter analysis of compressor blade sridharabc228 CFX 1 April 13, 2017 20:10
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Coupled 1D/3D STAR-CD Training CD adapco Group Marketing Siemens 1 November 13, 2002 16:48
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
