Outlet Pressure Increasing Resulting in Reverse Flow
Old   May 22, 2023, 16:35
Default Outlet Pressure Increasing Resulting in Reverse Flow
Lucas Cavalcante
Syncrochicity is on a distinguished road
Hey all,
I am fairly new to Ansys and trying to simulate a simple heat exchanger as part of a project.
I have the inlet conditions set as pressure inlets and the outlet conditions set as mass flow outlets. The goal of the project is to design a heat exchanger which minimizes the pressure drop of the hot side. I know the inlet pressure and figured it would be best to find what the simulation estimates the outlet pressure to be.
The problem I am running into is that the hot side outlet pressure keeps diverging, much higher than the inlet pressure resulting in a reverse flow (400 bar vs 20 Bar). Any idea how to remedy this?
My mesh seems pretty good with an average skewness of 0.00196 and average orthogonality of 0.97336. I have also tried specifying "prevent reverse flow" but this led to a decreasing outlet pressure initially, as expected, and then a drastic increase.
Feel free to ask for more clarification.
Thanks for the help!
Syncrochicity is offline   Reply With Quote
convergence issues, divergence in fluent, fluent - parallel
Changing flow Mach No. by changing Pressure Outlet in Pressure driven supersonic flow Goel FLUENT 2 June 22, 2021 05:48
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 08:32
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
